Hi guys,
This isn't really a bug as such but I couldn't find anywhere else to report it. I just downloaded HWiNFO v6.26 Portable zip from the FossHub mirror. Normally I just copy and replace HWiNFO64.exe and ignore the rest of the files. This time, however, I couldn't help noticing that HWiNFO64.ini is missing. Both 32-bit files are there, but there is only an .exe for 64-bit.
I can confirm that the same happens when downloaded from any source listed in the "Free Download" drop-downs on the HWiNFO downloads page.
I suspect I may have missed an announcement or something saying that HWiNFO64 doesn't need the .ini. If I have then please let me know. If not then you may want to add the missing file. (I've never actually opened the .ini files so I don't know if users could simply change the 32 to 64 and use it or not. I guess there will be some differences though.)
Thanks,
Leah
Thanks,
Leah
