HWiNFO64 System Crash
hOttt
Hi!
The app is crashing with my system. I have a Samsung Ativ Book 9 Lite (AMD A6-1450) with Windows Single Language 8.1 and Catalyst 13.12.
I attached the debug files.
I was reading the threads and miss the one with the answer for my problem. Disable the "Wake disabled GPUs" option solve the problem.
Thanks for your feedback. This seems to be again a problem in the OpenCL driver of the GPU.
I'll add a workaround for this in the next build, until then your solution (disable "Wake disabled GPUs") should be applied.
