'Ideal' Sensors to Display? (Ryzen 7 5800x & 2070 Super)
BryHuncho17
Recently, I've been getting more serious about making sure my temps and what not are within an ideal range and I added the HWiNFO plugin to my Stream Deck, however - I want to make sure I'm tracking the most important things.
  • If you had to pick 6 sensors to specifically display on my deck, which would they be?
    • I'm currently only displaying 3 things; my CPU Die (average), GPU Temp & GPU Hot Spot.
  • In the HWiNFO plugin on my Stream Deck, there's a 'Min/Max' field....I'm assuming I'd enter the 'Minimum' value from HWiNFO for the specified sensor as well as the 'Maximum' value?
Any help would be greatly appreciated! If you have any questions or need screenshots of anything, let me know. Thank ya'll very much!
