Incorrect monitor information
jjlee
Hi. Martin
Monitor model and values collected seems to be incorrect.
Please see attached.
The actual monitor information is as follow:
Model: 24m47vq
Vertical Size: 29.9 cm
Horizontal Size: 53.1 cm
Resolution: 1920x1080(FHD)
Can you help?
Thank you.
  • DESKTOP-DSD2P80.HTM
Thanks. I will fix the monitor name in the next HWiNFO build, but the physical dimensions are parameters that are reported by the monitor itself.
There are 2 monitors attached with different IDs. Are both the same model ?
Yes, they are the same model.
Thanks in advance.
