Is there a way to choose which sensors to log?
htwingnut
Is there a way to choose which sensors to log? I see the "log all" and don't see a way to selectively choose to log certain sensors. I only want to log about a dozen of them instead of weeding through everything. Is there a way to do this? Thanks.
arg8
If you click on each sensor in the table (within the Configure dialog), and you then un-tick "Show Reading" for each sensor you are not interested in logging, then they won't appear in the log file.
But perhaps there is a better method?
Thanks for answering arg8. That's currently the only way to filter logging, hope it's sufficient...
