objecttothis
I have three issues:
1- The OSD that HWiNFO is sending has a colon after the label to RTSS and there does not appear to be a way to remove the separator character or change it to a different character. I'd like it to be consistent with the OSD sent from MSI Afterburner (Lines 1-3 below)
2- If I select more than one value for a given line and check the box to show the label in the OSD it puts the label in the format of "label1, label2: value1, value2", but I would like the label to appear in the column next to the value. ("label1 value1 label2 value 2"). I can't see where this is currently possible.
3- Is it possible to right-align labels/values in their columns? Currently labels are left aligned, but allowing right-aligning would be super nice.
