Laptop Asus N551JM CPU FAN RPM reading
gamba69
Good afternoon!
Unfortunately, HwInfo does not display information about the value of the CPU FAN RPM.
However, SpeedFan displays information about RPM.
Is it possible to fix this problem?
The report file and debugging are attached.
Thank you!
  • CETUS.ZIP
OK, fan speed monitoring on this model can be supported. It will be added in the next HWiNFO build.
Please try the new build 3385 Beta, it should report fan speeds for your notebook.
