Latest two HWInfo versions taking long to load (related to RAM temp)
Hi :)
I noticed, in the last two versions HWInfo seems to struggle to detect my TridentZ Neo RAM sticks.
When that happens HWinfo takes about 20s to open and when it does the RAM sticks are no present in the list.
It would be obviously good to either fix this, or to be able to bypass RAM stick temps altogether since is nothing I really need. (I'll try removing them from the list for now)
Thank you :)
Please attach the HWiNFO Debug File with sensor data so I can see more precisely why this happens.
Are you perhaps running some other monitoring or RGB control tool? That could be causing a conflict.
