LCD program not displayable.
g1real
I seem to be unable to get the LCD application to display on my LCD, it shows in the list of applications of the panel software, but on my LCD screen itself I cannot for the life of me select it. No it's not disabled.
Am I missing a toggle option or something? I've enabled some sensors to be displayed but the application remains inactive. I really like this application so far because it's such a good source of logging and monitoring. The G15 option would finish the deal for me.
Have you also properly configured HWiNFO to display the chosen values on LG LCD in Sensors / Configuration ? Can you attach a screenshot of the configuration and let me know which version of the LG GamePanel software/drivers are you using?
For better experience with the LG keyboard LCDs you migt use the LCDHost, which is now compatible with HWiNFO too.
g1real
Actually, nevermind. I made the mistake of selecting screen 2 in the assumption I had 4 tabs to play around with on the LCD display. :p
Works now when I put it on screen 1.
Edit: I couldn't really get LCDHost to work because I couldn't figure out how to grab the HWinfo values.
Edit: Is it possible I could get some assistance on that? I can't seem to select any category/group/value after I select HWinfo as monitoring text.
-LaRrY-
I have the same problem.
Installed the acutal Logitech Game Software (8.35) and the actual HWinfo64 4.04-1730.
It doenst matter what i try, display 1 or 2 or 3, Line 1-X, Column 1-X, Font or whatever.... it wont appear on my (first Version!) G15. It appears in the Panel but wont show anything on my Display.
Earlier i used C2DtoG15 but that wont work on i5-3450 CPU..... the only thing i wanna display is GPU Temp, CPU Usage on Cores and CPU Core Temp. Nothing else.
I also tried LCDHost but till i get somethin on my display i realise that its Monday again ;) and i still have the same problem like g1real.... LCDHost may be a bit "too heavy" for a "non-core" user aka "casual" ;)
Greets from Germany
-LaRrY-
I have just verified with Logitech Gaming Software v8.35 and both the G15 and G19 emulators and all works properly.
Are you sure you have correctly configured all the settings including color?
-LaRrY-
Here's how i made it (still not working):
1. Start of HWiNFO64
2. Go to Sensors
3. On the Sensor Screen i go to "Configure"
4. For example i select "CPU 0# Digital Thermal Sensor" and then "Core #1"
5. I click: "Show on LCD", Line 1, Column 1, Screen 1, Font 8
6. Click on Close
7. Click on "Close&Save"
Nothin is shown on my LCD.....
Anything important forgotten???
Greets -LaRrY-
You need to have the sensor window active, don't close it. So either have it open, or hide it using "Minimize All".
-LaRrY-
Oh Yeah.... that was the problem :D i thought it could be "closed" instead of minimized!
Thanks man, it's Workin!
Greets
-LaRrY-
wfor1pilot said:
I'm new (not sure this is the correct thread) but, like the software; want to be able to display sensors while playing games: Like this: (http://www.youtube.com/watch?v=VX1pfyCwpNQ). How do I enable that? -Davis :huh: :huh:
Please check this:
http://www.hwinfo.com/forum/Thread-Support-of-RTSS-Displaying-HWiNFO32-sensor-values-in-Games
There are also several other threads on other forums like here for example:
http://www.overclock.net/t/1229915/how-to-cpu-and-gpu-usage-along-with-fps-in-game
wfor1pilot
Please check this:
Will check them. Appreciate the help ! -Davis
