lost sensor from ite chip (CPU Temp, CPU Fan)
wawans1975
This happen if i enabled the igp and set vsoc to 1,3xxV (otherwise system unstable). If vsoc set to auto , then those sensor appears and read normally (on BIOS and on Windows).
This is weird anyone can explain this why, i thought those sensor just read temp and fan rpm?
when vsoc set to auto, cpu temp and cpu rpm gives no static /flat value when running cpu burner..
any recommendation app that can control CPU Fan RPM according to CPU Tdie ? or HWINFO64 can do that?
