Marvell 88SE9120, devices not detected
yekabo
it seems that any devices connected to this Marvell SATA 3.0 controller won't be listed under Drives.
Debug file in PM.
I see that you have the option "IDE Drive Scan" set to "Low-level". Please set it to "Safe Mode" and check if that maybe helps.
Also, according to the DBG file you provided, HWiNFO found the following drives:
INTEL SSDSC2CW060A3
ST31000524AS
SAMSUNG HD103SJ
Is neither of these drives connected to the Marvell SATA 3.0 controller ?
yekabo
Wow, that worked. Thanks for pointing it out. I had it left in low level mode after updating the driver. Before udpating, the result was the same in safe mode, no devices listed.
INTEL SSDSC2CW060A3
ST31000524AS
SAMSUNG HD103SJ
None of those, the devices connected to the Marvell controller are
SCSI\CdRomTSSTcorpCDDVDW_SH-222AB_SB01
SCSI\DiskWDC_WD30EZRX-00DC0B0____80.0
Thanks for your feedback, I'm glad that it's resolved now.
Indeed, upgrading storage drivers often helps to solve such problems.
