memory module showing differently
ruggb
why is this showing one module different then the an identical one? row 2 & 3 are the same part number.
What happened to [P0 CHANNEL A/DIMM 1]?
Row 2 is missing the location as it can't be determined. For this to work accurately, it's also required that the memory module has a unique serial number.
They were bought as a pair, so I assume the s/n are OK. But it may be an insertion issue. I'll have to check that. But I believe it worked ok under W10. Now I have W11.
The memory is indicating 32GB, which is correct.
