My GPU VR temps disappeared?
idred
I used to be able to read the VR temps of my Nvidia 970 GTX. Now I don't see it on the list.
I remember it being in its own group separate from the GPU temp group. Simply not there anymore.
The CPU VR temps are there.
Anyone have an idea on why these values would disappear? I did flash my GPU bios and then they disappeared, but I only changed a couple of values in it.
Thanks.
That might be somehow related to the BIOS reflash. You might try to flash the original BIOS back and see if they come back.
You might also attach the HWiNFO Debug File with sensor data and I will check I can can see something there.
