Hi all
Pretty new when it comes to HWiNFO.
I have an issue with an old Dell T5500 tower. It has at least 4 fans in total (excluding GPU fan). At first, it was so noisy but I got it quieter by turning on Intel SpeedStep in BIOS. There is nothing else in the BIOS that helps.
While it is better, there is still a noisy fan that I believe to be a system chipset fan, most likely the north bridge chipset. I haven't been able to disconnect the fan to verify due to it being stubborn despite having a go at it with pliers. Regardless, the fan needs to be there anyway.
I get this message when I initially run HWiNFO.
After hitting continue, I am able to find the sensor that seems to be driving all the fans as seen in this image. I suspect the noisy fan is the one reported to be at 4300RPM.
However, I am not having much luck when it comes to fan control, although I am aware that there are other programs that may be better with respect to fan control. Setting manual seems to have no effect and custom auto doesn't make sense as I don't know which fan is which etc.
The fan connector appears to be 4 pin but I see 5 different wires in total (green, yellow/red, black green). Image attached.
Can anyone point me in the right direction as to my next step. Googling says this motherboard's fan control may not be configurable although a few have reported being able to control the CPU fan and HDD bay fan. I have found nothing with respect to the chipset system fans.
Thoughts would be appreciated. Thanks
