Open main window from Sensors
rehsd
I'm likely missing something obvious. If I have HWiNFO configured to run only Sensors on startup, how can I quickly open the Main or Summary windows? Is the only way to open settings, flip settings around, close the app and relaunch?
Edit: I now see options to open Main and Summary when I right click the HWiNFO system tray icon (which is great). Is this new in 7.0? I don't recall seeing this in older versions.
It was present on older versions too.
The system scan is specially optimized in Sensor-only mode for faster startup by omitting scan of items not needed for sensors. So to get the main window, it has to be enabled and start over again.
rehsd
See . On only one system have I ever seen the options in the system tray icon for Show All, Main, and Summary. I would like to see these options on my other computers, but I cannot figure out how to make these options show up. It seems like I've tried every combination in Settings, General / User Interface. What do I need to do to get the additional options to show up on my computers? Thanks!
The "Main" option is not available when you run in Sensor-only mode. As already explained above, you need to deactivate that first.
rehsd
I had the Main option on one PC even when run in Sensor-only mode, hence my confusion/frustration. (I just verified that was the case on one of my PCs.) Possibly a bug? I have now cycled the Sensor-only option on the Welcome screen and the HWiINFO process several times, and it's behaving as you describe.
Basically, the Settings, General / User Interface choices have nothing at all to do with whether or not the extra menu options show up on the system tray icon.
As I understand it, the only way to get back to the Main window when in Sensors-only mode is to open settings, enable Show Welcome Screen, Quit the application, run it again, and de-select Sensors-only on the Welcome screen. Is that right?
Have you considered keeping the option for the Main window on the systray icon even when in Sensors-only mode, or adding a button to the bottom of the Sensors screen to directly launch the Main window? I realize a more detailed scan would then be needed at that point when choosing the menu/button. Currently, it seems like a lot of effort to simply pull up the Main window when in Sensors-only mode.
