TheGodofCruelty
Hello, I have an issue that started happening more and more over the past few weeks, I am suspecting the PSU but I am not entirely sure, I did some testing and it over time started to happen in games where before it didn't happen, a few months back it happened when I ran a heavily modded sims 3 and started warframe at the same time, I wrote it off as a sims problem, now these last 3 days the PC shut down within 10 mins from starting Baldurs Gate 3 which I could play for literal days without any shutdowns a few weeks ago, also happened in elden ring when a lot of stuff happened at the same time.
Hardware is:
MSI Z390 PRO-A
i9 9900KF non-OC
2x 16G RAM (where I am deeply sorry that I can't for the love of me remember what brand I got since the stickers fell off and I can't remember where I ordered them)
ROG Strix GeForce RTX 2080Ti 11G (which had it's fans replaced, might be another culprit? bad chinese quality parts maybe?)
Corsair RM850x PSU which is a little over 3 years old (it did run 24/7 tho which is why I kinda suspect this being the culprit)
No Mechanical parts other than the Chassis and GPU fans, CPU is Watercooled with an AIO cooler
1x NVMe and 2x Regular SATA SSD
I attached a HWInfo log since I have no clue what to look for exactly, however I do sincerely hope something indicates it's the PSU because if it's the CPU or Board then I am sincerely screwed no way I can afford a new system and getting an LGA1151 board around here is almost impossible given the age...
Edit: One thing I forgot, no errors, Bluescreens or anything in the system logs, only thing that shows up is a critical KernelPower event.
Why do I also suspect the GPU fans as possible culprit? because one of them according to the logs spins at sometimes up to 3 million RPM apparently...
Hardware is:
MSI Z390 PRO-A
i9 9900KF non-OC
