PCH temperature showing 0.0 after a Sleep or Hibernation
markj
I am constantly monitoring and getting alerts when GPU, CPU or PCH temp reach a specific value.
However, after a Sleep or Hibernation, PCH temperature showing 0.0
Thanksfor your help!
This looks like a BIOS problem, which doesn't properly reinitialize PCH thermal monitoring after sleep.
If you restart HWiNFO after sleep, will it then show a correct PCH temperature ?
Thank you!
No, restart Hwinfo after sleep does not show correct PCH temperature. If you are right, any chance to fix this issue?
I'm afraid in such case the problem is most probably in the BIOS and can't be fixed in HWiNFO.
You should contact ASRock support, hopefully they will fix it in a new BIOS release.
