Sensor alert settings for drive failure / Drive warning
Good morning
I am trying to set the Drive Warning and Drive Failure alert and I see that the display is currently Yes or No (Boolean value) but the manual says it will contain a value of the number of failures or warnings
The options are "< 0" or ">=0" so I am not sure which one to select as I would want to set it to ">0" so that it will alert if it contains a number 1 or more but I do not have that option and if I set it to ">= 0" then if it is 0 (boolean) it should report but I don't want to see it
Please help
"Drive Failure" and "Drive Warning" can be only Yes/No (so 1 or 0).
When there's a real problem observed, then a new entry will appear as "Failure: xxxxxx" or "Warning: xxxxxx" where "xxxxxx" is the name of problem and the value will show the number of events.
Thank you for your reply
So as I understand it I will set it to ">= 1" and then it should report it when it happens
Is this correct
