Sensor Monitoring
Cmp_Cmndo
Mini computer is a Coofun UM700, identical to Minisforum UM700, both made by Besstar Tech Limited.
Motherboard voltage monitoring appears to be off (low) by a factor of around 2X for most of them, others may not exist.
Vbat of 1.617 is the one that caught my eye. The computer is new, the battery is new.
I'll need some reference showing correct values. Is there some tool from them or at least the BIOS showing correct values?
I'll try to adjust this in the next build. But not quite sure as even the BIOS seems to report some odd values like Memory Voltage only 0.5V
