Setting Time for HWiNFO??
K2style
Hey there, I was wondering if you could help me with something. I'm currently using the HwInfo application for burn-in tests on certain machines, but I've noticed that the time on the testing software and hardware info don't match up after Ive ended the recording. This is causing some issues when trying to zero in on specific time frames in case of errors or just even wanting to see what a temp was. Is there any way to set or correct the time in the HwInfo application? I'd really appreciate any help you can give me. Thanks!
K2style
Ok, never mind. I found that when I open the log file in excel. The time and date format just needed to be changed. Once I do this it reads The time started instead of minutes logged. Thanks for checking in though I really appreciate it. Have a good day.
