I'm using an Asus ROG Strix X570-F Gaming AMD X570. Starting temps of two sensors (Temp2 and Temp5) ar 95 and 96 degrees celsius. After some minutes on idle the temps go down to 80 and 83 degress. While gaming the temps are around 75 and 77 degrees. Under full load (CPU and GPU) the temps drop to around 61 degrees.
The PWM controller and VRMs are 12(4)+2(1) Phase ASP1106 (4+2) and 14x Vishay SIC639 DrMOS (50A). Max. operating junction temperature of the SIC639 is 150 degrees celsius. Junction temperature is 135 degrees.
Maybe this is a distance temp (150-95=55 (or 135-95=40) degrees after turning the pc on)? Didn't find the specs for ASP1106 but I think its 150 degrees, too. I guess you know the specs better cause you have implemented the ASP1106 in release 4.x
