Start though CMD and log output
prodigz
I am trying to start HWINFO32 though the CMD line and output a single value to a file.
I just need to capture the Vbat and output it to a txt or CSV.
Is there an easy way to do this?
So far I have the INI set in a way that I can start it from the CMD and it only outputs the Vbat in the log file but I can not figure out how to start auto logging on start up.
Is there a way to have it auto log to a file with out any interaction?
Thanks,
Matt
prodigz
No, I'm sorry this feature is not supported.
Are there any plans to enable this feature?  It seems like it would be very useful for anyone using it for remote administration.
