Strange PCH temperature
Prontus
pouWv0WLp
Temperature 4 is sometimes srtange too i saw numbers like -88C minimum and 125C maximum.
Temperature 4-6 are most probably invalid (not connected) and should be ignored.
Can you please check with GIGABYTE EasyTune tool what temperatures does it show and if the PCH is same there ?
Prontus
Well I know that temperatures 5 and 6 are VRM temps It mostly shows normal values only the minumum and maximum is crazy but only since tomorrow so I dont know what happened. It showed that my maximum vcore was 2.2v which would kill my cpu
All other temperatures including PCH seem to be correct and in sync with the GIGABYTE ET tool.
