Testing PC with no OS
Alexko
Hi
Just wondering if there is anyway I can test a used gaming pc,for faults heat damage etc, that I have seen for sale with no OS?
it has a dedicated GPU also
Any ideas?
There are two options:
1. Either make a DOS bootable medium and use HWiNFO for DOS, or
2. Make a WinPE bootable medium and use HWiNFO32
It can report sensor information, but ehm, noise? ;) It is also no longer maintained, so it doesn't support later systems.
Alexko
sensor info?
Hehe noise- I meant will it stress test the components to reveal heat issues which would make the fans noisy.
If I run this dos program will I still be taking the risk of the PC being faulty?
This is the used pc
