unreal engine settings optimizations
sixcentgeorge
the monitor windows is very cool with its side-duplication [ may be a load & save could be added ]
i use it when i play a game to check temps
while i was playing latest batman , that has a lot of troubles with pcs .
after editing few settings in the ini , gameplay is better , unreal engine 3 has a lot of settings for memory and D3D .
may be the monitor of hwinfo could check settings and optimize them for the player and its computer ?
here are links for official doc
https://udn.epicgames.com/Three/SystemSettings.html
https://docs.unrealengine.com/latest/INT/Engine/Performance/index.html
two pages showing basic changes :
http://www.shacknews.com/article/90173/5-batman-arkham-knight-pc-performance-optimization-tips
http://steamcommunity.com/app/208650/discussions/0/594821545178755667
the two guides does not talk about the memory settings .  hwinfo and its monitor know the "truth" and can maximize memories use  [ cpu and gpu rams ] with monitoring sessions , checking the changes effects at next play  .
that should be only positive for the gamer and its computer , i think that should also be very easy to do and add to hwinfo
beside the batman games , there is also mafia2 that uses the engine and also physx , cars .
player is in cities as a driver and there are no loading except when he goes inside a  building
I'm sorry, but performing such changes is definitively not a task for a tool like HWiNFO.
sixcentgeorge
i do not think so...a game that has plenty of available settings , plus uses at max the cpu and gpu [ plus the ram and hd ] is a top software for windows...
i understand you are not having time or energy to do that...but latest batman is no more sold because of bugs...so if you make a tool that can change the game and make it playable...you ll be very rich soon...i mean that is a nice way to advert your work and hwinfo...not sure there will be a second chance so easy to catch ...
