K Kol12 Well-Known Member Apr 14, 2017 #21 All is good with 3139. It sounds as though you have fixed the fixed the runtime error so my debug may have come a little to late? Is is best to run HWiNFO as administrator? Can you tell me again what settings are stored in the .ini file?
Martin HWiNFO Author Staff member Apr 14, 2017 #22 Yes, I have fixed it meanwhile and will release a new public Beta build with this fix soon. Sure, you need to run HWiNFO as Administrator. Just open the INI file in a text editor (Notepad) and you will see what settings are stored there.
K Kol12 Well-Known Member Apr 14, 2017 #23 Great thanks! Is it possible to minimize the sensors window and have the summary window remain on the desktop rather minimizing with the sensors window?
Martin HWiNFO Author Staff member Apr 14, 2017 #24 This can be done when the "Minimize Sensors instead of closing" option is enabled, but then the sensors window will just be minimized, not hidden.
