PhotM
I promise you that I am not trying to find Red Herrings for you, but I have another very strange one(nothing to do with the registry this time
This is a case of appearing, then disappearing when I turn Debug mode on, and then reappearing when I turn it off, of the VRM measurements that are new. They also appear and disappear in HWiNFOMonitor as well. So there are TWO distinct categories of Bugs here.
Your new VRM focused Values appear to be having a decimal point issues, 1000 Degrees, volts, watts. All of the new VRM Measurements disappear in Debug mode as you will see in the two .PNG with Debug file. Other system info that is there is still valued since I have not changed my internal hardware. My external USB 3.0 Hub is not there because I'm have some trouble with and have it disconnected.
I was wondering if you would mind giving us a brief explanation of what VRM is?
Martin, this is another issue. is it possible to make the Sensors Screen larger(no Horizontal Scroll Bar) or at least have it remember the new resizing in the .INI file or a .CONFIG file that we could port and save for future installs?
If you need some more, Martin, let me know.
Best Regards,
Crysta
Best Regards,
Crysta
