AC Adapter Info
likaz
Do you plan to add support to read what type of AC adapter is connected? For example, Dell software can determine what is the wattage of connected AC adapter.
AFAIK there's no standard for monitoring of AC adapters and I'm not even aware of any adapter capable of this.
This is the first time I hear about such feature and I assume DELL is using some proprietary method for this, which is not disclosed to others.
You can see what is being detected about connected AC adapter by Dell's app here:
Maybe this article will give you some clues how those features are implemented: https://hclxing.wordpress.com/2014/02/26/hacking-a-dell-power-adapter-final-not-really/
Thanks, but this is not sufficient to implement software reading that information.
I have did a bit of RE and now I know how Dell's app works. It captures BIOS events and process it and I can do that myself. The one thing I was a bit disappointed to find out is that it does not read AC adapter parameters directly, it only responds to events. But I would guess that that data could still be read if someone would know where exactly to read it from.
By the way, not only Dell, but also HP and Lenovo offers the same feature to detect incompatible PSUs.
Adding support to read the type of AC adapter connected, including wattage detection, would be a useful feature. Many manufacturers, like Dell, use specific protocols and circuits (like one-wire communication) built into their adapters and devices to share this information. Implementing such a feature would require both hardware and firmware updates to enable communication between the adapter and the device.
If your device or software doesn’t currently support this functionality, it might not be feasible to add without new hardware. However, if your system has the necessary hardware capabilities, this could potentially be enabled through a firmware or software update. It’s worth checking with your manufacturer or looking into tools designed for hardware diagnostics.
