hello,
first post here, HWinfo is good enough to merit me joining the forum and posting.
however being in the bug section, im am posting as i have a problem. i see a consistant discrepancy between two different sensors, and i'm unsure as to which to trust.
in the blue corner, we have the CPU #0 AMD FX8320 showing 30 celcius when idle
in the red corner we have the Nuvoton NCT68776F showing 45 celcius at idle
idle being browsing with firefox and a handful of tabs
sometimes the difference between the two readings can be up to 25C, but mostly if hangs around 15c difference.
from searching around the net, i understand that there are discrepancies and that reading temperatures on computers is not an exact science, i would however like to know, which reading is most likely the most acurate. I dont play many games but i do write and record music, and a heavy load can make the temperatures soar! the other night i had a reading of over 75c from the nuvoton, the amd showed 60c, high enough to make me stop what i was doing and go back to browsing.
i will be buying a water block and rad, something along the lines of a coolermaster sedion 120 or antec kuhler h2O 620, as the stock cooler is very very noisy, i feel like im inside an aeroplane sometimes. but until then......
thanks in advance
allan
thanks in advance
allan
