AMD Tctl/Tdie and CPU Package Power not logged into csv on some processors
Running latest beta build 7.13-4605, on laptop ryzen 4000 series CPUs, these 2 values are logged into the log csv file, but on ryzen 5800X + MSI B550M Mortar, these 2 values are not logged. However, they are still visible in the sensor window under the enhanced section. Some other values under the same enhanced section like IOD hotspot temp are correctly logged.
Log file attached for reference.
  • HWiNFO_LOG_11849703.zip
Are those values enabled for Logging? Check in Sensor Settings - Custom - "Logged".
Indeed it's not, but I thought by default it is enabled, as when I run this on another PC with 5600x, they are logged.
Is there anyway to force enable them without having the user to click into the settings manually? E,g, via registry
