ARCTIC Liquid Freezer II Compatibility?
Canister
I recently emailed the cooler company Arctic to see if they supported your HWiNFO64 with the ARCTIC Liquid Freezer II 280 A-RGB Rev 3. I am considering buying that cooler for my next PC. They replied that they did not know for sure if your software was supported, but said "our coolers connect to the motherboard via CPU_Fan header. If the software can read that slot, then it should work fine!"
My current NZXT cooler has an extra USB connector that I assumed HWiNFO used. Would HWiNFO64 work fully with that Arctic cooler?
Thanks!
If the cooler is connected using standard fan header to the mainboard, then yes, it should be supported.
