Auto Fit Crash
Zodler
Since version 7.14 if you enable Auto Fit on a Graph, the program crashes after 3-4 hours. When I disable Auto Fit, it does not crash.
Thanks, but I don't think the Debug File will help in this case.
I'm looking into this now, but so far I wasn't able to reproduce the crash. But I found one potential issue, though not sure if that's causing it...
I will try to fix this in the next build, but I'm still not 100% sure that this is the same issue you're experiencing.. only 98% sure :)
Zodler
If yours crashes, that's it. What happens to yours? Run it for 6-7 hours with auto fit on.
Mine is on
Network: Intel Wi-Fi 6E AX210 160MHz
- Current DL rate
- Current UP rate
Zodler
Ok, it is official. It has been solved. It has been running for more than 12 hours and no crash. I'm shutting down my PC.
