anotheruname
I installed HWinfo64 last week and the auto start feature worked without issues.
The other day I got a message about an update which I installed, auto start then ceased to work.
After that every time HWinfo opened I got the same update available message!
It started to drive me nuts so I uninstalled and re-installed.
This got rid of the crazy update messages but now no matter what I do auto start refuses to work.
It doesn't matter whether UAC is enabled or disabled. I've looked at these forums and if I understand things correctly there should be an entry to start HWinfo in Task Scheduler and there isn't.
I've now uninstalled and reinstalled numerous times, each time with a fresh download from the website. Nothing I do works. I've tried both 32 and 64 bit versions
Auto start is ticked. I can manually start and minimise to the notification tray but as soon as I restart I have to manually start it again.
I've checked in Task Manager and HWinfo doesn't show unless I start it manually.
I'm using Windows 7 64bit.
