Pakkazull
Board: Asrock B550 Steel Legend
Sensor: Nuvoton NCT6796D
HWinFO version: 7.15-4620
After a seemingly arbitrary amount (I've seen 10 minutes, I've seen 30) of time running HWiNFO64, the motherboard sensor will stop reporting CPU temp and will instead just freeze at one value. The CPU itself however still reports correct values in HWiNFO64, but the problem is the fan curves follow the motherboard-reported (frozen) temp, which basically means that HWiNFO64 also locks my fans into one speed. Other programs that monitor CPU temp through the motherboard (such as Asrock's A-Tuning) also display this frozen value; the only way to fix this seems to be to reboot the PC and just not open HWiNFO64.
Any ideas?
Any ideas?
