Background Tray Color
Is it at all possible to remove the background tray color and to change the font color as well? The forced background color sort of kills the look of my tray bar since everything else is no background lol
Loving HWiNFO by the way. Needed something to watch the CPU ingame with Afterburner with my new H80 in place.
You can choose any background color of the tray color item - either via Sensor/Configure or right-click on the tray icon. So you should be able to choose a color same as the tray bar itself.
In case you need to watch certain sensor values in games with Afterburner, you can also configure HWiNFO to output values to the Afterburner RTSS/OSD. So you don't need the tray icons, but can see the values rendered straight into games.
