Beta 579.3383 X TTRing Plus
TZero
I've been using all versions of HWINFO64, Aquasuite (version 2018) and TTRing RGB Plus (version 1.1.6) without any problem.
After I install the beta version 579.3383 only Thermaltake software (TTRing RGB Plus) can no longer read the temperatures of HWInfo. After I return to using version 574.3363 everything returns to normal.
:huh:
RE: Beta 574.3383 X TTRing Plus
This is because of some recent security changes in the latest Beta of HWiNFO (v5.79-3383) - it might break compatibility with a (very) few applications.
This will be fixed either in a new HWiNFO Beta version, or update to Thermaltake software.
TZero
:D
thanks
