I have a Asus P8Z77 Pro MB with 3570k, with default settings I noticed over a small period of time my block clock will show like 102mhz in max column.
This seems to happen after display goes to sleep (note this system has sleep disabled in power plan and hibernation disabled (C states enabled in bios still).
Now I did search around, and found if I uncheck periodic polling it is fine, but my understanding its not checking bus speed regularly.
Now compared to other app like CPU-Z, that has a known 99.9mhz showing for 100mhz bus, but it has no min/max saved values.
I also have Openhardware monitor and it seems that it doesn't poll the bus either (never seen anything other than 100, even if I OC to say 101 for test.
So my question, is this a known problem reading bus clock, that it reads wrong value, I have periodic polling unchecked which does seem to work but feels like a hack to me as it not monitoring bus speed.
