Command line switch(es)
h8maintenance
Hi all,
I would like to use HWiNFO to feed the LCDHost applet for my G19 keyboard and also wish to start this program manually and not with Windows. Could you please tell me if there is a command-line switch to automatically start running the program in sensor mode only instead of having to tick the checkbox "run" every time I start the program? Thanks for the help.
You might want to enable the "Minimize Main Window on Startup" option in Configure. That will cause the initial window no longer to appear during startup.
h8maintenance
Thanks for the quick reply. Yep, it works as you advise and not like I thought to initially do it, i.e. by running the sensors option only.
Great program :) Keep up the good work.
Sarbon
When enable "Minimize Main Window on Startup" work perfect, but... HWiNFO not offer the possibility of returning back.
In tray icons, right click and only appears: Sensors, Summary and Quit
Main Info and Settings totally dissapears.
I have WinXP Pro 32 with HWiNFO 32 v3.94
Thanks in advance, awesome program :D
Please open the HWiNFO32.INI file (using notepad, wordpad or any other editor), go to the end of the file into the [Settings] section, find the MinimalizeMainWnd item and change it from 1 to 0.
