Big Elf
I've been using HWiNFO64 for 3 or 4 years and find it very useful. I use it mainly to report my Swiftech 35X pump speeds and as a quick check on system temperatures. I also like the option of displaying the pumps speeds in the 'Notification Area'.
I have noticed that with the later versions that CPU utilisation has jumped up quite a bit from around 1% in early versions e.g. version 3.80 to 8-9% in the later versions, specifically 4.32.
I've just uninstalled version 4.32 and installed 3.80 and can immediately notice the difference in CPU utilisation.
I know there's a lot more functionality and user customisation included in the later versions but wondered this increase in CPU utilisation is typical or if there's some features that can be 'switched' off to reduce it.
