Hey,
I'm not sure if this is HWiNFO or BIOS related (or something else)... however I'm suffering a weird issue: when I start up my machine I see 'typical' sensor readings on mobo and chipset temperature sensors and chassis fan RPM's (chafan 1 and 2 have fans connected). However, the readings are stuck. If I start playing a game the PC heats up and I can hear the chassis fans speed up correctly (controlled by BIOS based on chipset temp) but the temperatures and fanspeed reported in HWi never change.
When I restart HWi, the sensor readings 'update' to what they are really. After this, they also update/monitor correctly.
I have to do this after every system restart.
This problem is only for the CH7 sensors mentioned. Otherwise (CPU, GPU etc. monitoring) I have no problems with HWi, it's perfect and working perfectly.
I updated and reset HWiNFO yesterday to address this (I was on v6.14 previously), it didn't help. I'm on v6.28-4200 now.
Any comments?
Edit: I don't have any Asus monitoring software (eg AI Suite) installed, that would be accessing the same sensors. However I do have MSI Afterburner and Corsair iCUE running, and additionally Asus RGB software (Armory). AB and iCUE should not be accessing these sensors according to my understanding of the monitored item lists in those softwares.
Any comments?
