Kraken AIO Elite X360 not detected.
TDMayo
Good evening,
My Kraken AIO Elite 360 V2 (2024) is not currently showing as a sensor, this includes liquid temp, fan RPM and pump RPM.
(Note Pump RPM can be read via mobo as I have it on the pump connector, however this does show the correct info - it just is not pulling from Kraken)
I've confirmed that CAM is closed before running HWiNFO.
Running HWiNFO x64 8.16.5600
NZXT Kraken AIO Elite 350 V2 (2024) running on Firmware version 1.2.1.
Many thanks
Thank you. This seems to be a new model that we don't have support for yet.
I could try to handle it as the previous series, but not sure if that will work. Would have to be tested..
I'm happy to run any beta/test config you would like to give a try.
I can compare sensor data with CAM output to verify.
Hmm, that probably means it's not compatible with earlier versions.
Please attach a new Debug File from this build.
Thanks. Indeed, I'm afraid this seems to be using a different protocol and we don't have information about it yet, so can't support it :(
Thank you for taking the time to look into it.
I'll keep an eye on the release notes moving forward to see if it gets support.
