Disabling a sensor makes the sensor 10 rows below beeing disabled, and not the former.
M88Turbofan
If I right click on a Sensor and disable it's monitoring it will stop monitoring the sensor which is like 10 lines below ¯\_(ツ)_/¯
EDIT: HWinfo has fixed itself on it's own (no restart)
But the software behaves quite erratically sometimes. Like it changes parameters I didn't asked for on it's own. It once has enabled 50 tray icon sensors.
It looks like it has something to do with recently disabled / hidden sensors.
Kind regards
There might be some mismatch in settings, you might try to do a complete "Reset Preferences" if the issue persists or "Restore Original Order" in sensor settings.
