I have definitely low readings about power usage on ASUS Dominus Extreme + Intel Xeon W-3175X. As you can see CPU Package Power sensor states 7.552 W Maximum and this is after Passmark CPU test. In reality it should be much much more.
O.K.
First of all: enabling SVID will ofcourse severely damage OC capability. And for a monitoring software (mainly used to monitor OC situations) it's ludacriss... but never mind.
After enabling SVID things got better but still VERY VERY far away from reality.
First picture is max CPU Power draw after C23 according to HWi. Wattmeter on the wall shows 900W - meaning CPU arround 500-600W at least!!! ASUS AI Suite shows 530W CPU Power.
Now on idle AI Suite shows 115-120W, HWi - 45W
Second picture shows RealBench Stress test real time readings. Black showing 426W is AI Suite vs. 168W HWi. Obviously not even close.
P.S. Just for the sake of the test i have disabled SVID and ran C23 again. AI Suite shows 3W, HWi 1.25W. It seems that HWi readings are always arrond 2.5x lower than supposed.
P.P.S. I've read other posts blaming AI Suite or Armory Crate: did try with AI Suite disabled and no Armory Crate installed at all - nothing changed: 200W Max reading.
