Steps to reproduce the problem:
1. Install the latest version of Kaspersky AV: https://products.s.kaspersky-labs.c...3033377c44454c7c31/kis21.2.16.590en_26095.exe
2. Update it's database
3. Launch the latest version of HWiNFO (it installs the driver as well)
4. Try to update the databse of Kaspersky again and try to scan any forder from context menu
Actual behavior:
Kaspersky update doesn't work correctly while HWiNFO us running (the tray icon doesnt change to the one with the 'Earth')
Kapersky scan doesn't work correctly as well, as it should show the tosts (windows notifications) when the scan is complete, but it doesn't happen while HWiNFO is running
You can close HWiNFO and look, the tray icon of KIS will change once HWiNFO has been closed and you'll see the windows notifications finally. So the HWiNFO or even the driver block those functions
Expected Behavior:
HWiNFO wont block KIS functions as it was in version 150 of the driver and broke since 151.
I can even record a video of this bug or send you a vmware snapshot. Please fix it.
P.S. my OS is Windows 10 20H2 build 19042 x64.
Actual behavior:
Expected Behavior:
