Hope you are well. I am not sure if this is a bug or not but the CPU core 0 reports an effective clock speed of 4MHz under load. Ive noticed sometimes it jumps around such that three other cores report this also for a second before going back to a stable 3700mhz.
Hi Martin, I ran prime 95 on it and had all cores running and it still shows the result above in my first post. When its not under load it drops to zero. It appears like its permanently sleeping. Have attached the debug file if that helps.
I'm looking into this, but can't figure out what might be the problem in HWiNFO. Does it show the same if you enable the "Snapshot CPU Polling" option ?
I still have the issue related to this.
Core 0 T0 always shows higher effective clock than rest of cores.
Even when I set fixed low voltage of just 1 volt in BIOS to cause clock stretching on my R5 3600, Core 0 T0 effective clock still goes up to full boost (clearly not right), while rest of the threads go down to ~3300 MHz.
Happens on latest beta to date.
6.34 shows correct values.
Yes, I tried that, and it works.
I didn't use it before, because Average Effective frequency value was halved. All good now. Thanks!
Although, I'm a bit curious what happened in 6.40 that led to Core 0 T0's wrong value.
