Whiskeyomega
Yea the reverse the min score is the one you look at on load. Tell you how under the voltages are being reported to get more out your cpu.thats my max
Yea so 97.8% is fine means its telling the cpu that its 2.2% off the correct voltage. which probably isnt on purpose its so small.this is what i got after bios update View attachment 4674
the 97.8 is minimum so is that the one i go off sorry for all the questions not very good with softwareYea so 97.8% is fine means its telling the cpu that its 2.2% off the correct voltage. which probably isnt on purpose its so small.
Yes. Thats why i explained whythe 97.8 is minimum so is that the one i go off sorry for all the questions not very good with software
I have an R5 3600 cooled by an Arctic Freezer 34 with 2 fans, with a Gigabyte B450 Aorus Elite, nothing changed, except XMP. The airflow in the case is really good, ambient temps were 22-23 °C. (3-3 intake and exhaust fans.)
The minimum deviation with Cinebench R20 was 88.3% (I attached a picture of another test) which is not a lot, but I would like to ask for some help how to set it properly.
My concerns are more focused on temps, with a maximum of ~96°C, which is a lot in my opinion.
Peak Core Voltages are 1,25V when the R20 is running.
Can anybody help me what to do to not destroy my CPU?
Thanks.
Hmm just did a test with idle and with a cinebench 20 test , but i get these results :
with cinebench 20 i get these results:
while playing a game cpu @11% i get these results:
hardware is :
amd ryzen 9 3900x
asus Rog strix x570- E
(Newest bios)
what can i do about this ? , just wait till they come with a new bios firmware ? or what can i do now to not destroy my cpu ?
hope someone can help me , Thanks.
Hello!
My specs:
Motherboard: ASUS ROG Strix X570-F Gaming (BIOS version: 1407, the latest)
CPU: Ryzen 7 3700X
Everything is on factory value (D.O.C.P. is enabled, but no OC or something).
The current value was during the test between 104-107%. Is it accaptable? If no, what I need to change in BIOS (I don't have experience in the field). The temperature of CPU was between 59-61 °C with Noctua NH-U12A (the temp in my room is about 24 °C).
On idle was the PRD 454%. This is not problem?
Thank you for your help!
Thats acceptible. Idle readings don't matter.Could please someone check my results?
I dont end understanding those percentages... So if its over 100% means you are using less power so its good, and if its under 100% means you are asking more power to the processor that can harm it?
I get between 129% and 318% at idle (about 220% average), currently running Cinebench R20 and I get 128-131%.
Is it because I overclocked my CPU ?
CPU : Ryzen 5 3600, OC @ 3.8 GHz, 1.1V vCore
MB : Asus X570 TUF Gaming PLUS, bios v1407 (04/01/2020)
Temp : 38,6°C (average, mostly idle) ; 59,8°C (max = running CInebench R20)
