Assimilator1
No, below 95% is, read the op it will tell you this.Is 117% full load bad for my cpu?
At 117% it appears your CPU is being slightly throttled (underclocked), is your CPU running hot?
I get between 129% and 318% at idle (about 220% average), currently running Cinebench R20 and I get 128-131%.
Is it because I overclocked my CPU ?
CPU : Ryzen 5 3600, OC @ 3.8 GHz, 1.1V vCore
MB : Asus X570 TUF Gaming PLUS, bios v1407 (04/01/2020)
Temp : 38,6°C (average, mostly idle) ; 59,8°C (max = running CInebench R20)
Don’t worry about this issue, it has been blown out of proportion, this sort of thing has been going on with Intel boards for years now so nothing new and nothing to worry about. Your CPUis fine and will be fine.
No, look at screenshots in OP. The issue is a mobo manufacturer will use VRM values the make the CPU think that their is less amps being used so CPU thinks it has more headroom than it actually has. The effect is higher temperatures due to increased voltage for a cpu being tricked into thinking it only has 50 amp VRM utilized so CPU thinks it has more VRM headroom to boost higher. The built in processor monitoring will prevent CPU from cooking itself using AMD boosting algorithms.No, below 95% is, read the op it will tell you this.
You're being way too vague about this and you haven't said whether you're referring to THGs article or the op's post.Don’t worry about this issue, it has been blown out of proportion, this sort of thing has been going on with Intel boards for years now so nothing new and nothing to worry about. Your CPU is fine and will be fine.
Whilst I agree that very quick CPU burn out (as per THGs headline) is very unlikely (unless the PRD is seriously under), a more modest but still under reporting figure will run the CPU hotter & will have more power running through it. Depending how much, this will shorten CPU life the same as overclocking to varying degrees. It might not be much, but it's there.
Tom’s Hardware made it sound like chipocalypse and it isn’t. Inte mobo manufacturers have been doing this sort of thing for years.Ryzen CPUs have a built in monitoring system that prevents it from damaging itself or being damaged while using auto boasting algorithms. It may not prevent damage if you manually overclock too hard. I have yet to encounter CPUs that ended up dying early deathsdue to extra voltage under normal use, only with extreme overclocking usage are you likely to burn out a CPU.
40 GHz? lol, that's some overclock you've got!No, in fact i am running 40Ghz as i said, so i am undervolting a little bit for better temperatures (Ryzen 5 3600 holds 42Ghz by default)
I don't know why you're quoting me when I understand what the PRD is aboutNo, look at screenshots in OP. The issue is a mobo manufacturer will use VRM values the make the CPU think that their is less amps being used so CPU thinks it has more headroom than it actually has. The effect is higher temperatures due to increased voltage for a cpu being tricked into thinking it only has 50 amp VRM utilized so CPU thinks it has more VRM headroom to boost higher. The built in processor monitoring will prevent CPU from cooking itself using AMD boosting algorithms.
People need to stop worrying about this, it isn’t as bad as some have made it out to be.
Ryzen chips are able to go up to 95C before throttling significantly. Same as Intel chips. Are you going to own that CPU for 10 or more years? Probably not, so you don’t need to worry about it as the auto boosting and Ryzen FIT chip health monitoring will prevent it from burning out significantly early.I mean, any of % values should be a problem if there is no overheat in the CPU, right? (>80 degrees celcius).
95C is the absolute redline and I wouldn't be running the CPU that hot! At those temps life could be an issue if keeping it for even 5 yrs (which many people do).
Also, when you're running a CPU hotter, that will in itself cause it to use more power.
Good figure
Agentnathan
Oh & btw, with the stock cooler & settings, my 3600 was throttling at ~90C, are you sure about that 95C figure?
Re your 1st point, yes it does, as I recall it, high temp's means higher resistance, which means slightly more power usage. It was an AnandTech article where I 1st come across this, but atm I can't remember which one as it was at least a few years ago!Running hotter won’t necessarily use more power, electrons flow more freely, to a point, when conductor is heated. Vacuum tubes operate because of heating causing electrons to flow.
I agree that 95C is hot, but not redline, maybe a few hundred revs below redline, chip manufacturers build in safety margins just like nearly all manufacturers. Will the life of the chip be shortened running at 95C 24/7? Yes, but not by as much as you might think. Remember, RDNA GPUs have 110C hotspots and they still run fine.
It is for Ryzen 2 as well, see screenshot. No, the colder a conductor is, the greater its resistance to current flow. Like I said, heat lowers resistance up to a point. Vacuum tubes in tube amps have to be heated to a certain temp before the resistance drops enough for electrons flow. CPUs are similar. However, the resistance to electron flow probably comes into play at various higher temps with various material. At some point the resistance may increase when temps reach a certain level, but it will vary depending on the material.I'm glad I'm not the op!I'd be tearing my hair out with the number of people here who've posted & not bothered to read the op, or read it properly! About 1/2 I reckon
Btw 95C is for the Ryzen 1 not 2, see here https://www.amd.com/en/products/cpu/amd-ryzen-5-2600x
Not seeing any max temps for the 3600 page though!
Agreed about safety margins btw.
You're misunderstanding what PRD is, it's what the CPU is being told the power usage is, not what the actual power is.maybe im dumb but I DONT GET IT ... With 150A setting (50% of the actual), YOU HAVE THE BEST FREQUENCY 4106.6MHz, THE LOWEST POWER CONSUMPTION 91.553W AND LOWEST and peak CPU temperature of 79°C. T ???? so all wins no negatives or im i missing something here ( yes there is the ethical question etc) btw not ny native language, sorry
Sorry, I was wrong. Vacuum tubes have insulation effect so heating overcomes that insulation effect allowing electrons to flow.Agentnathan
Sorry but that's wrong, resistance drops with temperature in most materials (their are a few exceptions), hence superconductors have to be super cold.
I don't know what's going on vac tubes, I suspect that's down to something else. CPUs are not similar.
Your screen shot is of a Zen 12600 (I incorrectly stated Ryzen 1, 2 earlier, when I should've said Zen 1, 2.) Their appear to be no max temps listed for Zen 2, Ryzen 3000 series.
Btw, I got one thing wrong about power usage going up with temperatures, apparently it's mostly down to static leakage not resistance increasing. Checkout that thread and look at the tests he's done.
