I'm pretty sure this is not the case, indeed if the gpu usage is massive (~100%) it does *seem* that the measurement graph is continuous, but if you play something that does not peg the system it starts losing measurements and the aforementioned pattern shows up again (albeit with fewer or denser gaps, seemingly depending on usage? although im not sure). Moreover, checking task manager during this time again shows it being reported/graphed properly. This is definitely not normal.
