WHINFO Pro v7.25-4780 beta
I am trying to understand where HWINFO opens a graph of a sensor item in systems with multiple displays, and when new location coordinates are saved. I am seeing some inconsistent behavior that I will attempt to describe.
My system has 4 assorted displays connected. I attached a snip of the layout. Display #1 is the Main Display in Windows. I have set HWINFO to open the Sensor Status panel full size on display #3. This works fine. If I double-click on a sensor item to open a graph, the graph appears on display #2. This is a 7" stat display mounted inside my case. When the new HWINFO graph opens on that display, it is a pain to get my cursor over there to drag the graph to the display I want.
Once I drag the graph over, if I close the graph at the new location and reopen it, some graphs open at the new location but others (most) will open at the initial location again. Where it will open seems to vary by graph. If I change the size and colors, then close and reopen a graph, the color info is retained but not the size. The color changes will also apply to new graphs. If I save and close, all graphs will reopen where I left them last with final size and color.
So it appears that:
On my system, the default location for new graphs is display #2.
Graph location coordinates, size, and colors are all saved at "save and close".
Graph color changes seem to be saved as they are set and will apply when the graph is reopened, and to all new graphs.
Graph size is not saved when set but is saved at "save and close"
Graph location coordinates seems to be saved when set for some graphs but not for others, and always at "save and close"
I may be totally confused here but my questions are:
What are the default location coordinates for a new graph that has never been opened or altered?
Is there a way to change this globally (so my graphs stop opening on display #2)?
Is the data for graph location coordinates, size, and color written to the registry and if yes, when?
If a graph is dragged to a new location (display), when are the new location coordinates saved?
So it appears that:
