High Voltage and Clockspeeds when using HWinfo64
O.F.I.
Hi Martin.
For some time now I have had a high voltage, around 1.25 - 1.30 volts, when I use HWinfo64. And that's only when I'm on the desktop. In addition, my 13900K no longer clocks down, sometimes it clocks up to 5.8 GHZ. Utilization is usually less than 1%. All of this on the desktop too. I still use AquaSuite and have removed the sensors from HWinfo64, no change. For testing purposes I tested it with Aida64 Extreme. If I use this, the CPU clocks down and the voltage goes down. What could that be about?
Greetings and thank you in advance.
Maybe some other sensor causing higher load to read it. Hard to give an advice without knowing exact details.
Try to enable the "Profiling Time" column to check which sensor is taking excessive time to read.
Thank you for your quick answer. I reinstalled HWInfo and it was like that again, high voltage, higher clock. Then I deactivated the monitoring for the D5Next and the HighFlow Next again and look and behold, it immediately clocks down and the voltage also goes down.
